Red key light won't go off???
RE: Red key light won't go off???
ORIGINAL: Xtreme Hawg
Capt, he said his 07 ultra doesn't have the security system,so I'm sure theirs no FOB, but I may be wrong[sm=confused06.gif]... "D"
ORIGINAL: captsam54
[sm=popcorn.gif]Wheres your fob?? maybee......
Just computer ralated glitch or code problem??
ORIGINAL: captsam54
HHMM.. Just thinking.. why the red key display if no security???
ORIGINAL: captsam54
Thanks for the resposes. No LED's. Does have the HD plug up to unite the brake light with the rear turns. The "red key" is not a real bother but the fact that it will only start in neutral has the potential of being icky if the engine dies and requires a quick search for neutral. It does not show a code. Again it has no security system. Even tried disconectiong the battery w/o any luck.
ORIGINAL: rodeking
I have a 2007 ULTRA w/o the security system. The "red key" light stays on all of the time. Also the bike will not start unless it is neutral. Any ideas? This problem just started @ 2500 miles.
As for the light, I don't know what to say except that if you could find the wire feeding that LED you could cut it. I'm not sure if that would cause a fault code, so doing that would be experimental. Without the security system there is no need for the LED.
I've thought about cutting the wire and re-wiring it through a switch so the light could be activated when the bike is parked, simulating an active security system. Maybe add a blinker in the circuit if appropriate.
