Nice looking chart with fairly typical power curve w/ duals, or actually better than some. As an STD chart, you are getting 3-5 HP/TQ numbers higher than with the more common SAE measurment. Still nice numbers and good chart.
I had a 04 88ci Roadglide with Andrews 26 cams, ST 2 into 1 and SE air cleaner. Dyno tuned STD numbers were 77hp and 84 ft lbs. So your bike is making 95ci numbers compared to what I was getting.
Dyno chart from my 2004 Road Glide updated with the following:
95 C.I.
9.5:1 Compression Ratio
Branch PT reworked heads
Branch 515 cams
S&S cam gear drive
Feuling Oil Pump
Feuling Cam Plate
Stock exhaust with Kerker mufflers with Mikuni Baffle
