Fuel tank overflow tube routing
Old 08-30-2008, 01:59 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
Default Fuel tank overflow tube routing
Took the console of of my 08 Street Glide today to remove the tank. Well in taking off the console I failed to pay attention to where the tank overflow tube goes. Does it just coil up under the console an come out of the bottom??? There are two clips under the console to hold it I assume. I looked in the service manual but could not find anything.
Old 08-30-2008, 04:58 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
Anyone????
Old 08-30-2008, 05:35 PM
papifun's Avatar
papifun
papifun is offline
just looked at mine - ure right , comes out of bottom just behind the hell shifter behind console.
Old 08-30-2008, 07:41 PM
Garemlin's Avatar
Garemlin
Garemlin is offline
So yours just comes out of the bottom of the console under the seat and stops??? I am drawing a blank as to how mine was.
Can anyone snap a pic of theirs without the seat on???
Old 08-30-2008, 08:11 PM
BillinNY's Avatar
BillinNY
BillinNY is offline
PM sent.
Old 08-30-2008, 08:27 PM
DrPlastic's Avatar
DrPlastic
DrPlastic is offline
Mine runs under the console down around the battery then out the bottom of the frame behind the oil tank.
Old 08-31-2008, 09:36 AM
Garemlin's Avatar
Garemlin
Garemlin is offline
That is the vent hose. The one I am talking about is on the right side. It is connected to the underside of the console. There is a little hole under the filler door and that is where the hose is connected to.
Old 08-31-2008, 10:45 AM
DrPlastic's Avatar
DrPlastic
That must be the drain line that catches any overflow from the fuel filler.
Old 10-07-2020, 07:22 PM
intrepidxc's Avatar
intrepidxc
intrepidxc is offline
Necroing an old thread because I don't see the solution. Does anyone have an answer? Removed the tank during my audio install and didn't pay attention to the routing of the overflow line.
jackdiet
2018+ Softail Models
06-22-2021 03:43 AM
puntagorda
11-12-2007 02:57 PM
robot_head
09-24-2007 08:38 PM
Motown_HOG
06-27-2007 11:09 AM
ccgobama
07-02-2006 08:20 PM
Quick Reply: Fuel tank overflow tube routing
