95 Kit Upgrade
RE: 95 Kit Upgrade
Local dealer just had a special for $3000 you got the 95ci, HTCC heads, HTCC pistons, HTCC intake, choice of cams, HD remap, all gaskets etc everything installed. Included a dyno after 1000 miles but not a PCIII or custom map. They guaranteed 100 hp - 100tq. Lot of locals jumped on it.
RE: 95 Kit Upgrade
If you're going to spend your money to upgrade, you may want to do the 103 kit instead of the 95! If you compare a stock engine with Stage I kit, SERT, and proper dyno tuned to a 95 upgrade, the increase in torque and horsepower is minimal.
If you like to see a drastic increase in performance, spend a bit more money and get the 103 kit! You'll be much happier.
RE: 95 Kit Upgrade
ORIGINAL: Kahuna
RE: 95 Kit Upgrade
ORIGINAL: Kahuna
I have been putting some numbers together and can get Gear-driven Andrews TW37's, BigBoyz ported heads & bored jugs in a 95" config and all the necessary components (pistons, gaskets, adjuatable pushrods, etc) and install it myself for ~$1500. If I go with a Fueling SuperPump & lifters, it's still <$2k.
RE: 95 Kit Upgrade
Hmm I had 73hp and 81tq with stage one and PCIII custom map. After 95ci with heads pistons cams etc I have 101hp and 107tq. 26% IMHO is a significant increase. I did consider the 103 stroker but extra labor charge was 8 more hours plus the parts. Another $1500. A lot of difference between pulling the jugs and splitting the cases. If I was a wrench and doing it myself I would have done a 103 but alas I am a rider not a wrench so the 95ci!
ORIGINAL: Kahuna
RE: 95 Kit Upgrade
Branch flowmetrics port job on heads $840.00
Overbore stock cylinders $100.00
JE domed 10.5 pistons (from Branch) $250.00
Complete top end gasket set about $75.00
I did all the labor myself
Also did my own:
Andrews Gear drive TW-55G cams $550.00
Specialty tool rental $40.00
SE adjustable pushrods $120.00
New Lifters $80.00
Crane Hi4TC ignition $180.00 on Ebay.
Vance and Hines ProPipeHS $397.00
I realize you probably aren't planning to work on your own...but this will give you an idea how much labor they are gouging you for.[:'(]
I couldn't afford to do half of what I've done if I paid the $85.00/hr labor rate my local dealer wants. If you've got a halfway decent set of tools, a place to work over the winter (so you can take your time)...you can save A LOT of money.
Also did my own:
New Lifters $80.00
