oil leaking from exhaust port after buid
Old 03-06-2009, 04:47 AM
fxlowboy's Avatar
fxlowboy
fxlowboy is offline
Default oil leaking from exhaust port after buid
Just finish my 103 big bore and SE 255 cam stock head, i start the bike on wednesday for 2 or 3 minutes everything was ok so i stop the motor, yesterday i start the bike again and a white smoke came out from the the right side muffler and the smoke don't stop i check for a leak and found oil around the flange so i change the gasket and torque the bolt start the bike again and same problem.my oil level is ok
What can be wrong !!! valve ,oil ring ...
Old 03-06-2009, 05:19 AM
aclass's Avatar
aclass
aclass is offline
Could be a valve seal. If that doesnt fix it then you could have the rings in wrong OR your piston doesnt match the hole.
I had the same problem once, oil would literally drip out of my exhaust port. It was a mis match between jug and piston, my own stupid fault.
Old 03-06-2009, 11:50 AM
Northside's Avatar
Northside
Northside is offline
Had a buddy do a top end on an evo last year, same problem. It was a broken ring.
Old 03-07-2009, 05:59 PM
garyhendley's Avatar
garyhendley
garyhendley is offline
yep sounds like a ring bummer
Old 03-08-2009, 03:21 PM
fxlowboy's Avatar
fxlowboy
fxlowboy is offline
Found the problem, my mistake :-( the second compression ring was install upside down so the ring does'nt scrape the oil down.
Old 03-08-2009, 03:23 PM
n8dc's Avatar
n8dc
n8dc is offline
oops.. you will be smarter next time ..... The good news it wasnt a broken ring as that can mess the cylinder all up.... Dont want that ..
ironhead mike
Engine Mechanical Topics
08-23-2015 11:25 AM
Jim2012FLHRC
10-31-2012 12:36 AM
bigbdz16
Exhaust System Topics
10-06-2012 10:25 AM
tc_radar
08-11-2010 09:19 AM
chopscotty
Oil Archive (no new posts)
12-07-2006 09:33 PM
Quick Reply: oil leaking from exhaust port after buid
