Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
hello guys , I have a question for you .
I have a 1993 1200 sportster I purchased as a project . installed new .010 over KB pistons and heads were reworked at machine shop . the engine went together ok and started and ran strong . I put about 100 miles on it when noticed some smoke coming from exhaust pipe front cyl . removed head and found exhaust port wet with oil and oil puddling up on top of piston . I had the head rechecked from machine shop and they said it checked out ok ? the cyl. looks good (no visible scores on cyl. walls ) could that much oil be sucked up by piston rings ? or am I missing something else . just want to make sure before I put this back together .
thank you
ok thank you for replies but I did not mention during initial tear down I found broken exhaust valve on rear cylinder . I think I should check rods for damage . there was a lot of scores in cylinder walls with only 100 miles on engine
