Do you need to use Exhaust gaskets
Old 03-23-2009, 09:07 PM
youngrider's Avatar
youngrider
youngrider is offline
Default Do you need to use Exhaust gaskets
I was just wondering how many of you guys are not using gaskets on the head pipes? When I installed my duals the darn gaskets wouldnt fit so I left them out...havent had any leaks.
Old 03-23-2009, 09:12 PM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
I think you better put them in. Did you remove the old gaskets? The old ones usually need to be pried out with a screw driver or knife. If you left the old ones in then that is why the new ones would not fit.
Old 03-23-2009, 09:16 PM
JonnyD's Avatar
JonnyD
JonnyD is offline
I noticed the same thing on my last bike, almost put it together thinking they didn't fit. The old gaskets hide very well when crushed. When pulled you'll notice a nice big void where the new ones will go. The heat leaking out will most likely scorch your heat shields over time.
Old 03-23-2009, 09:25 PM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is online now
Not to mention the havoc that will happen if you've got 02 sensors.
Old 03-23-2009, 09:35 PM
King Crimson's Avatar
King Crimson
King Crimson is offline
Use a dental pick to pull out the old ones.
Old 03-23-2009, 09:44 PM
youngrider's Avatar
youngrider
I didnt remove any gaskets....I should be ok then I think....when I removed the stock head pipes I didnt see anything in there... the new head pipes fit pretty snug...so im sure the original gaskets are still in there
Old 03-23-2009, 09:59 PM
sniperduce's Avatar
sniperduce
sniperduce is offline
I think you are fine. I installed V&H True Duals last year on my 08 Ultra. I reused the stock gaskets and left them in place since they were fine. Good luck.
Old 03-24-2009, 03:42 PM
txfxstrider
I don't know what kind of bike you have but if it was my bike I would pull the pipes and the old gaskets and put in new gaskets. Not an expensive or difficult procedure but if I am going to work on my own bike, I want it done right. Jus' sayin'.
Old 03-24-2009, 04:16 PM
FX4's Avatar
FX4
FX4 is offline
Its a good way to burn an exhaust valve. Go back and put them in. Cold air touching those hot valves will warp them and eventually burn them.
Old 03-24-2009, 04:17 PM
FX4's Avatar
FX4
FX4 is offline
Nevermind you didn't remove the old ones. 50/50 if you get a leak or not.
Quick Reply: Do you need to use Exhaust gaskets
