EFI to Carb
Old 04-05-2009, 05:57 PM
Taylorized's Avatar
Taylorized
Taylorized is offline
Question Converting EFI to Carb 06 SG
I have a 06 SG that I want to convert from EFI to carb. Has anyone done this? Is there a kit to do this? I hate my EFI had it tuned 2 times and still not right so EFI is going bye bye Any help would be great THANKS
Old 04-05-2009, 06:18 PM
neonhomer's Avatar
neonhomer
neonhomer is offline
The best thing to do would be to find a 06 bike that was carbed, and to raid the harness and such from it. Then it would be a matter of buying the necessary parts.
Otherwise, it might end up being a hack job and not run right. If you have had it tuned twice by the same tuner and they haven't gotten it right, I would be requesting a refund and finding another tuner.
Old 04-05-2009, 06:30 PM
Taylorized's Avatar
Taylorized
Calling tommorow about the refund.
Old 04-05-2009, 06:31 PM
leohd's Avatar
leohd
leohd is offline
american bagger had a write up on it about 3 issues back, it can be done
Old 04-05-2009, 07:06 PM
molsen's Avatar
molsen
molsen is offline
I would find another tuner, before the change. Personally, I am a carb guy that is finding EFI to be a better solution. The learning curve sucks though. I am working around it and learning the system. A lot more can be chages and set up than a carb. BTW I cam from a Mikuni HSR 42, a great carb.
Old 04-05-2009, 07:07 PM
golfinfool's Avatar
golfinfool
golfinfool is offline
Take it to IndyWest Harley in Plainfield Indiana, they did a great job on my bike. It really seems like they know what they are doing. They take pride in customer satisfaction and will do almost anything to make sure you are satisfied. Great group to deal with.
Old 04-05-2009, 07:13 PM
rochkes's Avatar
rochkes
rochkes is offline
Take it to Wabash HD in Terra Haute and request that Scott Hunter do the tune. You will throw rocks at any carb after he is done tuning your bike.
Tuning an injected bike can be extremely frustrating. But once you learn how to do it yourself or find a great tuner, you will not have the desire to jump backwards.
Dennis
Old 04-05-2009, 07:38 PM
scooty's Avatar
scooty
scooty is offline
Default Efi
Don't give up on the EFI you just need to find a reputable shop to set it up and it should be fine.
Old 04-05-2009, 08:52 PM
Taylorized's Avatar
Taylorized
Mikuni HSR 42 also the best carb IMO
Old 04-05-2009, 10:19 PM
jdreed520's Avatar
jdreed520
jdreed520 is offline
If you still want to make the switch to a carb Here is the parts list, and you dont have to cut up your harness to do it.
Engine mount (with slot for choke) ……. 16315-99 $5.51
Choke cable ……. 29229-88B $8.80
Choke elbow ……. 27580-88 $2.18
Choke boot ……. 27582-88 $1.78
Intake manifold ……. 27613-99 $22.43
Manifold seals ……. 26995-86B $1.51 \\; X 2
Seal ring (carb/manifold)…… 27002-89 $4.91
Ignition Harness ……. 32435-00 $104.43
Manifold sensor (MAP) ……. 32316-99 $26.95
Manifold sensor seal \\; ……. 11291 $0.99
Retaining clip ……. 38723-99 $0.13
Retaining clip screw ……. 68042-99 $0.85
Stock Petcock- 61338-94D $53.00
Stock CV40 Carb- 27412-99D $168.00
MM EFI Tank Conversion from Pingel $40.00
Screamin'' Eagle Ignition 32721-01A $157.02
Quick Reply: EFI to Carb
