My Metzeler Rear Tire Won't Hold Air
1 Post
This is a long story, but I'll try to keep it as short as possible. I bought a used 2005 EGC (see sig picture below) about 4 1/2 months ago from the local Harley dealer. The dealer had installed new Metzeler tires front and rear before selling the bike to me.
After a couple of months, I noticed that I couldn't keep air in the rear tire because it kept leaking out. I contacted the dealer numerous times about the problem. I have taken my bike back to him at least 4 times for this problem.
The dealer has removed the tire and remounted it twice..... also replaced the valve stem. It still leaked air badly....... about a pound of air per day and sometimes more.
Last week, the dealer put a new rear wheel on it thinking that perhaps the wheel casting was porous and leaking. That didn't help either.
Yesterday, the dealer put a brand new Metzeler tire on the new wheel and of course put a new valve stem in the tire. The Service Manager checked the tire with MY TIRE GAUGE yesterday before I left the dealership. It had 39 psi pressure using my gauge.
Today I checked the pressure in the rear tire and it read 35 psi. It had lost 4 psi overnight. I couldn't believe it so I got another tire gauge and checked it with it. This gauge read 34 1/2 pounds.
By the way, the front tire has never had the slightest problem with holding air and it is a Metzeler too. When I check the air in it, it reads a consistent 39 psi every time I check it.
I called the Service Manager and told him of the pressure reading this morning and he said that it was impossible because they had installed everything new on it (tire, wheel, and valve). I told him that I didn't see how it could be leaking air, but I had checked it at least a dozen times today with two different gauges and got 34 1/2 to 35 psi each time. That's a loss of 4 or more psi overnight.
Then I began reading about the problems some people are having with these Metzeler tires made in Brazil. My tires were made in Brazil. One of them (the front one) has performed perfectly. The rear tire has been nothing but a problem since I got it. Even the replacement NEW tire is a problem since it won't hold air either. That's two brand new Metzeler tires on two different wheels that have been on the rear of my bike and neither one of them will hold air.
I'm about ready to tell the dealer to remove the Metzeler tires and put some Dunlop tires on there. Maybe the reason some people are having blowouts with Metzeler tires is because some of them won't hold air.
1 Post
However, I haven't left it overnight since they put the new wheel and new tire on the bike. I'll probably have to do that just to prove to them that this one is leaking too.
Thanks for your suggestion.
Yep, I already did that a few weeks ago. In fact, they kept the bike two nights. I think they suspected that I was letting air out of the tire.
you have to be awful pissed at your self to let the air out of your own tires I have metzlers on my bike and i prolly need to check the air again but I did it about a month ago for the first time while setting all winter and they were low but I dont suspect anything like yours..
1 Post
I didn't actually see the old wheel being removed and the new one being installed, but I'm almost certain they did so.
Yesterday, when they installed the new tire, I saw them take the bike out for a test ride after installing the new tire and I could see the blue coating on the whitewall. Also, the new tire still has some little rubber **** sticking out, so I'm certain it is a new tire.
Thanks for the idea though.
1 Post
I can't imagine the dealer going to all this trouble to avoid having to replace a $2 part.
By the way, so far, the dealer has been great about the problem. I haven't been charged a dime! But then again, the problem hasn't been fixed yet either, although the dealer has gone to a lot of trouble and expense in an attempt to do so.
