Loose ignition switch? Anybody have any ideas?
Hey guys, I took the bike out for a spin and it stalled out on me. It started back up and had no problems until I pulled into a restaurant and it happened again. I then started playing with the ignition switch giving it a very slight nudge and it turned off again. It appears that it somehow is losing contact when it's in the ignition mode. Could there be something loose in the switch like one of the "tumblers" or could the switch just be loose and needs tightening? Just looking for some ideas before I tear into it.
I just switched out my bars on my 08 SG and I could tap on the iginition switch and it would go on and off. It ended up being the plug that connects from your lower fairing to to the wiring harness behind the outer fairing. Easiest way without taking apart you iginition is remove you outer fairing and look at your connection at the plug. I believe it is the Red/ Green wire that connects to the iginition switch. Mine was just not quite locked into the connector. Pushed it in and all is good. Hope this helps.
