2006 FLHX Lights fuse blowing
My 06 FLHX is blowing the "Lights" Fuse every time I turn the ign switch on. My brake light, blinkers still work, but the trim light and running light will not work. I have unplugged the socket going to the taillight assembly, and as soon as I turn the switch it blows the 15amp fuse.
Would love a idea or two.
Short
Sounds like a dead short someplace near the light(s) affected. You might look for a chaffed or crimped wire someplace where the wires go through the fender or wherever they make a sharp bend or are tied or restrained by a clip.
That's as far as my expertise goes on this one. Had a similar situation with my passing lamps on an '06 Steet Glide, and it turned out a wire had chaffed and shorted on the bracket.
Good luck.
Good luck.
Thanks guys.
No I didn't add anything new. I completely unplugged the taillight harness, I am guessing the accent light on the tip of the finder is the one running next to the radio antenna. Does that run on the same circuit? It does not light up either. I will try unplugging it also, but I have blown my last 15amp fuse. Have to wait till the morning.
Keep the hints coming.
Thx
Thx
kjcalig
08-30-2011 09:31 AM
