Blowing fuses?????
Old Jan 21, 2009 | 04:25 PM
cmose's Avatar
cmose
Default Blowing fuses?????
Done some work on my 99 FLHR and had the head light and driving lights off. I had to re solder the wires in the driving lights and once i put it back together I keep blowing fuses every time I turn my driving lights on. I have check the connections on the lights and changed the connections but still blow a fuse every time i turn them on. Any suggestions?
Old Jan 21, 2009 | 08:38 PM
dh2683's Avatar
dh2683
YOU HAVE A SHORT Something changed after you soldered them.
Unplug both driving lights at the lamp. Turn switch on and see if fuse blows. If it does not, plug in one light at a time until the fuse blows.Now you know where the short is.
Old Jan 22, 2009 | 08:11 AM
katobird's Avatar
katobird
sounds like the solder is touching making it a grounding point...look close this includes the light base, the bulb may complete the circuit
Old Jan 22, 2009 | 08:13 AM
cmose's Avatar
cmose
Fixed. I found a wire that was pinched.
Thanks
Old Jan 22, 2009 | 11:26 AM
HDRider2002's Avatar
HDRider2002
i was going to suggest the pinched wire, that will do it everytime. I went through a box of fuses when replacing my handlebars as i had the highbeam wire pinched, but didn't knwo it until i turned on the highbeams!
Old Jan 22, 2009 | 08:44 PM
cmose's Avatar
cmose
Took 5 fuses and an hour break before I found my mistake.
Old Mar 22, 2009 | 04:23 PM
swjohnson111's Avatar
swjohnson111
Stage III
Default Fuse blow when engine starts
I have a similar problem, the head light fuse blow when I start the engine. It is OK with just the ignition switch on but when I start the engine the fuse blows immediately.
Old Mar 24, 2012 | 03:40 PM
Errolt's Avatar
Errolt
1st Gear
Angry Same problem, headlamp fuse blows
I have same problem, headlamp fuse blows when I start the engine, but not every start.
inhershey
Electrical/Lighting/Alarm
13
Jul 24, 2017 11:53 PM
mgav20@cox.net
May 16, 2016 02:07 PM
johnnyocc
Oct 25, 2011 06:03 PM
C.H.L.
Apr 13, 2010 11:35 PM
harley9607
Apr 10, 2008 10:33 AM
