Just splurged. Picked up the ST SuperMeg for my Road Glide and the PCV.
I did a ton of research and boiled it down to the SuperMeg 2-1 or D&D Fatcat 2-1. Ultimately two decision criteria pushed me toward SuperTrapp (again).
1) I have the same exhaust on my Dyna and it has been fantastic - Sound - performance - quality - tune-ability etc.
2) I have read instances of guys thinking they were developing tinnitus from the D&D Fatcat high freq noise output.
I can't afford any more high freq hearing loss or I'll need a medical waiver to fly. Right now the Army will waive decapitation given the tempo overseas (shortage of pilots) .... but if the situation changes .... I need to retain acceptable high freq hearing.
My Dyna is not EFI so the PCV will be a new winter toy with a whole new learning curve.
I'm looking forward to rectifying the stock mediocre performance and tapping into all the lower end TQ potential in the 96 CIs.
I'll give a full report when I get some proprioceptive (butt-dyno) results to share.
T
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
I have not yet begun to defile myself.
2001 Dyna Lowrider
2009 Road Glide
AH-64D Apache
The power commander is only useful on EFI bikes, it will do nothing for bike with a carburetor. Is that a typo?
...gene
__________________
2003 Road King Classic
SE Air, Slip-ons, ME880
Andrews EZ Pushrods
Thundermax w/Autotune
Max Power 71.22, Max Torque 80.54 @6000ft elevation (pre-TMax)
you will absolutely love this combo been running a usbIII and supermeg for years on my 03 road king went thru several systems till my tuner said try this I can ride all day with out noise fatigue. make sure to buy the powercomander from Jamie you will be much better off than buying it local.
I bought both the pipe and PCV from Fuel Moto. I talked to Jamie and they're preloading the PCV for the SuperTrapp and SE Filter. I'm still toying around with my intake options.....
I feel like a kid in a candy store.
__________________
2001 Dyna Lowrider
2009 Road Glide
AH-64D Apache
Getting the stock pipes off was a bit of a PITA but the rest was pretty simple and straight forward. PCV took less than ten minutes to install - super easy on an 09.
SE Stage 1 air cleaner - easy install. I like the "oilless" filter. Hate oiling the filter on my Lowrider.
The SuperTrapp Supermeg "fitment" is a little lacking with the collector heat shield being the problem child. The same issue exists on my Dyna. It's not a big deal - about a 1/8th inch gap at the widest point between the front head pipe heat shield and the collector heat shield. I played around with the P-Clamp and the hose clamps and even the mounting point on the underside of the XMSN.
The finish (chrome) is excellent. Very nice. A little polishing with Wizards metal sealer and POW!!! the pipes look stunning.
Performance - the lower end torque is phenomenal. She accelerates like a raped ape in the "usable" rpm range for a guy like me. I don't much care about breaking 100 mph. I do like have an instant and arm straining response to rolling the throttle back. I used all 20 discs that come with the exhaust. The result is the low throaty rumble I've come to associate with the SuperTrapp. It sounds far better than the stock exhaust. A tad bit louder than stock and the note says performance.
I personally like that my new pipes are not really that loud unless I get on it. I REALLY dig the huge boost in torque.
I'm a happy dude. Next....... lowers? Maybe cams? Probably the HID lights.
Jamie / FuelMoto - Thanks for the great service.
__________________
2001 Dyna Lowrider
2009 Road Glide
AH-64D Apache
I had the same fit trouble with the shield too..... I got a perfect fit by loseing he front and rear pipe heat shields then used a block of wood and tapped the muffler heat shield forward untill it all lined up then tightned up all the clamps...muffler shield first..
