MORE brake squeal
Old 06-29-2006, 04:42 PM
carsoni's Avatar
carsoni
carsoni is offline
Default MORE brake squeal
I have had rear brake squeal since about new. anybody else have this problem? the fronts are fine but the rear squeal is loud as hell[:@]
Old 06-29-2006, 06:48 PM
Kahuna's Avatar
Kahuna
Kahuna is offline
Default RE: MORE brake squeal
Sounds like you are using more rear brake than the fronts. The squeals are coming from too much brake dust collecting on the back of your brake pads. You need to clean the dust off your rear wheel often. You can try to blow the dust off with a air sprayer. Brake cleaner would do the trick, as long as you don't get it on the brake pad surface.
ORIGINAL: carsoni
Old 06-29-2006, 07:53 PM
Suburban28's Avatar
Suburban28
Suburban28 is offline
I now have the front brake squeal.[&:]
Old 06-29-2006, 11:00 PM
bay13's Avatar
bay13
bay13 is offline
I had front brake squeel, to get rid of it I put on the floating rotors, no more front brake squeel. Now the back is acting up now and then. I'm going to try taking the pads off, cleaning things up good and use a high temp silicon grease on the backing plates. Hope that does it, if not I'll put the floating rotor on the rear as well.
Old 07-05-2006, 05:15 PM
06ALULTRA's Avatar
06ALULTRA
06ALULTRA is offline
I have a rear squeal if I don't wash the rear wheel brake dust off frequently
Old 07-05-2006, 06:33 PM
bountyhunter's Avatar
bountyhunter
bountyhunter is offline
Toss the stock rotors in the scrap heap (with the stock exhaust)....floaters are the only way to go...standard issue on CVO's, Dyna's, V-Rod's & any performance bike on the market.
Old 07-05-2006, 06:35 PM
cutacroshorty's Avatar
cutacroshorty
cutacroshorty is offline
My front brakes squeal really bad.
Old 05-12-2007, 10:59 PM
toadmanor's Avatar
toadmanor
toadmanor is offline
My front brakes squealed terribly. Dealer said my pads were glazed over badly. Probably according to him that I had over heated the brakes too early. So for $119 he put on new pads. Not warranty but operator error. I have used them very lightly to prevent glazing. Well here we are about 300 miles onto them and they are starting to squeak again.
I cant afford $119 every 500 miles.
WTF should I do?
Old 05-12-2007, 11:08 PM
Peekaboo Bob's Avatar
Peekaboo Bob
Peekaboo Bob is offline
Go back to the dealer, tell him he's full of ****, and you want your bike fixed without some BS story about breaking in pads.
Old 05-12-2007, 11:15 PM
TerryM's Avatar
TerryM
TerryM is offline
My brakes on 06 flhrs started doing this after about 100 miles of being brand new. When i dropped off for the 1000 mile service, they flipped the rotors on the front it has not come back. I believe this a known issue, at least with 06 touring bikes. Call your dealer, they did mine under warranty...
Quick Reply: MORE brake squeal
