Portable Sirius radios
Maybe I am not reading things right. The FMDA25 FM driect adapter I thought was suppose to allow you to use your bikes regular antenna and thus not have to use the dot antenna. Directions that came with the FMDA25 shows you unplug the bike antenna from the radio and plug it into the female antenna receptacle on the FM direct and plug the male connector from FM direct into the radio and then plug the last adapter plug from FM direct in the the FM out jack on the sirius unit. Then tune the HK and sirius unit to the same FM frequency. It mentions nothing about hooking up an antenna to the antenna jack of the sirius unit (as thought that was the purpose of the FMDA25 unit to begin with, to eliminate the need for the extra antenna).
Having said all that, you still need the antenna that came with the sat radio!!! Without that, you're not receiving the signal from the satellites. The bikes antenna is not compatible and besides, you're plugging the FM Direct Adapter to the FM "out" port! So, plug the sat receivers antenna in and watch it work.
Ride Safe,
Steve R.
I have my original Starmate inside the Tour-Pak. It's attached to a Mix-It board which is wired to the aux plug-in in the oem radio. My GPS is also connected to the Mix-It and the board allows the signal strength boost plus prioritizes the GPS when it needs to. Requires running a couple wires under the tank console. Everything is neatly velcroed to the Tour- Pak wall. Just can't change the station on the Sirius while riding. Shredsurf has a nice spot on the bars to mount the head unit. Batwing makes it a bit more complicated. I am pleased with my set-up and I can easily remove the Starmate to take it into work or my house.
Im using my Iphone with the Sirius App works well 95% of the time. I use a docking port cable that plugs into the bottom of the phone and charges and splits to a AUX cable that i plug into the radio only downside is if you are in a non cell area , no phone signal-no radio so i change to ITunes and keep riding.
On the RG im using the Iron Aces Mount and can also use the mount for data loging with my Power Vision.
Go to TSS Electronics online and purchase the kit that mounts
To your handle bars on the clutch side. The antenna and all needed
hardware are included. It rides good there and the kit even comes with
a rain cover. You can try to come up with some other style mount but
Your just wasting time. I tried the suction cup to the wind shield and with
vibration, I was afraid it would come off and hit my tank!
Out of curiosity, is there some kind of adapter that will allow you to maintain the handlebar radio controls? That's one of the main things that would keep me from considering an aftermarket radio head but it's not something I've looked into because I'm not unhappy with the factory HK radio. Just wondering!
Ride Safe,
Steve R.
