What size air compressor/tank?
I just retired and expect to do a lot of touring, now that we've moved back to the States.
I'd like to be doing more of my own maintenance, and lots of touring will mean lots of tire changes.
As I'm outfitting my garage, what size air compressor/reservoir would be needed to deliver the oomph necessary to seat the beads on a tire? I won't be running any air tools, so this is really just about changing the tires.
I've got the craftsman version of this http://www.sears.com/shc/s/p_10153_1...ir+Compressors. But I bought it because I'm a carpenter and needed something that would keep up with me when I was framing, but if you just want something to change tires with you can probably get by with a "pancake" like this http://www.sears.com/shc/s/p_10153_1...ir+Compressors and be fine with it. I always buy a little bit bigger whatever I need just to allow for future "growth". Hope this helps.
I agree with Jeff. You don't need a big one for for what you describe, but might need a little bigger than a pancake. Pancakes aren't good for much more than nail guns cause the tanks are so small. I would do at least a 20 gallon tank. Personally I also prefer the oil lubricated compressors over the diaphragm versions.
If you think you are ever going to run air tools I would go bigger.
I've got one of the upright vertical tanked Sears Craftsman 26 gal. compressors. It can barely keep up with any of my air tools. And its "Always" cutting on and running for ever to keep 90 PSI up in the tank. Not to mention that its so freaking loud it needs to be out in a cave in the back 40 to keep from just driving you in sane with its own racket. I H8 it.
http://www.sears.com/shc/s/p_10153_1...6770000P?mv=rr
I've just replaced it with an a much older unit a 1 H.P. Champion Model "K" two stage pistion model, 40 Gallon tank, with very low mileage. Even though this unit is 30's to 40's vintage I can work around and listen to all day.
Forget a new noisy model, stick with oil iron, its quiet, and built to out last anything and sometimes you can get a real deal on them.
You need to look at the CFM output of the compressor and compare it to the CFM requirements of the tools you want to run.....I agree you want at least 20 gallons. I would also skip on cheaper oil-free compressors. They are usually more noisy and have a shorter lift. Look for a good cast iron pump.
Thanks for the replies. I'm hoping that a little pancake will provide enough volume from the reservoir to seat the bead on a rim. I don't imagine ever buying any air tools since any wrenching I do is purely amateur, so I'm less worried about flow rate and keeping up with multiple tools than I am about having enough "pop" to get a tire back on.
