Checking Fork Oil
Checking Fork Oil
I have been in the search looking for the answer to this, but I didn't have any luck.
When the fork oil is considered to be at the proper level it is a certain distance from the top of the fork tube.
I read this distance is approx. 12" on a bagger.
My question is.... Is this 12" distance with the bike sitting on the ground with the weight on the forks or with the bike on a jack and the forks extended?
I know I could just put in the 10.8 oz's and call it good, but I want to make a tool to check from the top.
If someone could link me to the answer or give me the answer it will be appreciated.
Thanks a lot!!
Thanks a lot!!
I have the syringe and tubing and everything I need except the exact measurement from the top of the fork tube to the fluid.
If someone wouldn't mind looking in the service manual for these numbers it would sure help me out.
Thank you!
