doherty powerpacc
doherty powerpacc
anyone here running an powerpacc air cleaner on a 08 or better tourer w/throttle by wire?any problems with blowby?ive been thinking of getting one and see that the powervents dont work with the electronic throttle assy.i would be puttng it on a stock engine and if their is a problem w/blowby what did you do to get around it.also anyone with a built engine having any problems?i know you can put the breather assys.(mystfree)in the heads but other than that,whqt r you guys doing?
I am waiting for mine to get here, so I can't give direct information on how they work with TBW. Hoping it gets here in the next day or two. I talked at lengths to Tim about blow by and the setup for 08+ models with TBW before ordering mine. I had also talked to a few forum members about it and one vendor who tried one around a year ago and wasn't happy with it (so I had my concerns)
Tim said they have changed a few things for the TBW cleaner and are now including a crossover tube that is not pictured for 08+ bikes but can be seen in a few pics for other years. You then have the option to run a hose and T it into the back plate for internal breathing. Tim said this is fine if you don't notice lots of blow by with the stock setup ( I didn't see much oil in my my stock system when I removed it) After more talk and him explaining how the powervents are designed to work, we discussed an option to use one inline powervent on the end of the crossover tube. For now I am going to run it open and if I notice lots of oil, I will put a hose on the end of the vent and route the blow by elsewhere.
While I do not know if this is the greatest solution, I am not sure there is much more that can be done if someone does not want to feed blow by back to the air cleaner. I will take pics of mine once I get it and get it installed. Send me a pm and I can send you some of them once i am done. I think in the end, it will be worth as many rave about this air cleaner
Tim is running a sale right now and mentioned it will probably continue for awhile. Price I paid is on his the website. Oh and free shipping. Although it must be on a train because I ordered Friday the 5th
Great pics Nozz! Have you ridden it yet? The crisp instantaneous throttle response is going to amaze you. Top shelf A/C!
Did you use one of the little nylon O-rings to place between the head and blowby assembly? I see the blue one on the breather bolt blowby assembly but I can't see if you put one between the head and bb assembly.
Yes, I used a smaller blue nylon on the back of the crossover tube which rests between the head and the tube.
As for riding it yet. maybe this pic will answer that question...........
I did fire it up and whacked the throttle a few times. It will all be new to me since I added exhaust, TTS and the air cleaner all at once. I have nothing to judge it by other than stock. So needless to say it is going to ROCK
Looks great. I just might have to do this to my '08 Ultra, the blow by on the 103 blows big time. I'm tired of carrying maxi-pads when I ride. Are you going to vent the Powervent to the a/c assembly or to the atmosphere? I noticed a 90 degree connection installed. Was there a plug installed prior to this?
I installed the TTS last year and it really is so much better then the SERT. The motor runs so much cooler.
