Help with Cometic Gaskets
Old 02-27-2010, 06:19 PM
WhiteGoldSG's Avatar
WhiteGoldSG
WhiteGoldSG is offline
Default Help with Cometic Gaskets
I am in themiddle of my motor buils, and about to put my rocker boxes back on. My question is, Hillside cycles sent me a Wiseco gasket kit that contains Cometic metal rocker box and rocker box cover gaskets. the insert from Wiseco says to "use gascacinch or similar product on all copper gaskets" do I have to use the sealant, i always heard that sealant is a bad idea. Also, the raised surfaces on these gaskets face up when installing..correct? thanks guys.
Old 02-27-2010, 06:42 PM
FLYING's Avatar
FLYING
FLYING is offline
Using any type of a silicone sealant is bad as it could get in to the oiling system and all it does is plug stuff up.It never disolves so I will not use it on any surface that could let it get in to the oil system.In the case of the rocker box covers for a metal gasket you can use KW Copper Coat.It has been around for many many years and I have used it many times with good results.
Old 02-27-2010, 07:40 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Take them back NOW. The metal gaskets always leak eventually, next week, next month, next year, you WILL be repalcing them. Get the red coated HD gaskets, they never leak!
Old 02-27-2010, 08:18 PM
thereal142's Avatar
thereal142
thereal142 is offline
I had a set of Cometic base gaskets fail on an 800cc 2-stroke Rotax triple sled motor I built. I wouldn't use them on anything again ever. I am, however, a believer in Wiseco.
Old 07-31-2010, 04:33 PM
TAZROD's Avatar
TAZROD
TAZROD is offline
Stage I
Default Cometic metal rocket box gaskets, raised surface up?
Do the raised surfaces on metal gaskets face up when installing? Installing on 90 Evo.
1996FXDSconv
EVO
16
01-30-2024 01:50 AM
Keithhu
07-15-2017 09:53 PM
izzyfutch
Ironhead
03-15-2011 09:28 AM
harleylay
03-09-2011 01:00 PM
1sportytrike
07-13-2006 09:16 AM
Quick Reply: Help with Cometic Gaskets
