Fuel Pak problems
Old 03-07-2010, 09:16 PM
HDRookie's Avatar
HDRookie
HDRookie is offline
Default Fuel Pak problems
Have anyone installed fuel pak and had problems with throttle response?
Old 03-07-2010, 09:22 PM
ashmarc's Avatar
ashmarc
ashmarc is offline
I can only speak for myself......did the stage one with all V&H parts..true duals, a/c & fuel pak...no problems at all.
Runs fantastic.
Old 03-07-2010, 09:25 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
Had problems with Fuel Paks running REALY lean right before they went REALY rich.
Old 03-07-2010, 09:26 PM
imskier2's Avatar
imskier2
imskier2 is offline
Sorry!! Did the same as previous OP and no problems.
Old 03-07-2010, 09:44 PM
cchips's Avatar
cchips
cchips is offline
Had a couple of little problems. Called them and they gave me a different program. No problems after that.
Old 03-07-2010, 11:43 PM
Mike's Avatar
Mike
Mike is offline
Is this a problem that developed over time, or right from the start? You did calibrate the throttle, right? Are you having a problem with hesitation, stumbling, or something else?
Old 03-08-2010, 06:08 AM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
On the fuel pack, I don't believe you can calibrate the throttle. If you can, please advise how...
Old 03-08-2010, 06:27 AM
navyman's Avatar
navyman
navyman is offline
No problems at all here.
Old 03-08-2010, 06:58 AM
MrMax's Avatar
MrMax
MrMax is offline
Step #19 of the setup procedure is to slowly roll the throttle open to WOT. As you do this you see the fuel pack calibrate itself from 0-100. This is the throttle calibration I believe he mentioned.
As for mine it was plug and play. Runs great with no issues whatsoever.
Old 03-08-2010, 06:59 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Thanks....
I'm also going to check the software version of my Fuel Pak today and assure that Mode 19 (throttle Setting) is set correctly....
Quick Reply: Fuel Pak problems
