Cruise control stopped working???
I was out riding today and my cruise control stopped working. I was on my way home after about 100 mile ride. It worked fine all day. The light on the dash for the cruise is on and I have the red cruise light. It will not engage and the light will not change from red to green.
I did notice that my 6th gear light stopped working at the same time.
All other controls are working fine.
Any ideas?
08 Ultra Classic
Any ideas?
08 Ultra Classic
I had the sensor replaced (under warranty) and have not had any problems since.
The same thing happened to me. Cruise would not come on except my check engine lite came on too. It was intermittent. I took it to the dealer and they had to change a micro switch in the cruise control. I had it go out once again coming back from Colorado. The same thing, cruise quit and the check engine lite again. Changed out the micro switch and everything worked. It has been about 10 months and it is OK so far.
mine was the fuse contacts...... you know the metal "holes/slots" the fuse slides into.
it as loose, i would push the fuse in and the contacts would push a way, so the fuse was only making contact once in a while. that was the first time.
the second time it was a bad switch, the switch breaks (inside) easily.
