anybody using the dobeck aka techlushion TFI
seems likei t would work for simple filter,exhaust mods, guy has a good resume
Mark Dobeck, founder of Dynojet, the same person who introduced the jet kit and the inertia dynamometer, formed a new company called Techlusion in 1997. The focus of the company was to develop a controller as a fuel solution for EFI vehicles which was believed to be the future of all powersport vehicles
Good product. . .I recommend it
Had one on my 2004 BMW R1150RT, which had a surging problem under certain conditions. The TFI solved it with the recommended settings (from Dobeck). I used it for over 4 years and it simply just worked. . .it was plug and play and never had to be changed after the initial setup.
Before I sold the bike, I did a circuit of the central U.S. which encompassed high altitudes / cold temps, low altitudes and desert heat and everything in between. . .the TFI performed flawlessley and the bike ran great under all conditions while getting an average of 47 MPG.
Although I used conservative settings to optimize fuel savings, it could be dialed up for performance as well. All this and you don't need a laptop to adjust it. . . .I highly recommend it--it's a great value for what it does.
I had one on my 2004 Road King Classic and never had any problems with it. I also put on my 09 Ultra and haven't had any problems with either. The Road King had Fullsac true dual conversion, slip-ons, air cleaner and the Stage I download. My '09 has the air cleaner and slip-ons.
http://www.dobeckperformance.com/ thanks fo rthe replies so far!!
I've used it with just an ac and pipes and now with 103 heads, works fine. Just 3 pods to adjust, idle, 1/2 & wfo if I remember correctly. I played with it at first but found the tech that installed it did as good a job as I could. It's not as robust as say a power commander but as stated above it works.
