Stage III 103 and manual decomp???
My 10 SG is in the shop now having the Stage III 103 kit installed. I forgot to mention it to the mechanics last week, but just how important is a manual decompression lever on this bike? Starting while hot, some folks seem to need it frequently, while others don't and have good luck with the auto decomp.
Ya think I should call them today and have manuals put on now while the bike is apart?
FWIW, I live in Colorado.
Thanks.
Thanks.
I would suggest you have compression releases installed while the bike is down. Not much of an expense now, but will be alot more to tear down and do later if needed.
As far as manual or automatic, the manuals are cheaper and very reliable. But I have never known anyone personally who had trouble with the automatic ones.
Dennis
Dennis
Thanks.
Thanks.
I have a 103" Stage III in my '09 UC and I don't have compression releases at all. So far (21,000 miles in 55 weeks), I have not had a situation where I couldn't get the motor to turn over. I do have 10.5:1 comp ration as well.
If you have the $ to do the manuals, I'd so go for it as an extra sense of comfort...but not an absolute necessity!
You're going to love the 103...Riding up Vail Pass, Floyd Hill, Wilkerson Pass, Monarch Pass, Wolf Creek Pass...all in 6th gear at 65 - 70 mph and just cruising on up is a blast!!
Cuzkee,
I'll call the guys at Sun and see how much manuals are to install, and at what stage of tear-down the bike is in now.
Thanks for the tips guys!
Yeah, if the heads are still off it should be around $100 for the machine work and the releases. I did it on mine and am glad I did.
I just finished a 103" kit and went for the automatic ones, no reason for not using the manual ones,But what they didnt say was the computer has to be turned on at the dealers to run auto releases so while i waited to see the dealer my bike started ok without them but the starter was making alot more noise.now that they are working the bike starts great im glad i did it.
Running 251 cams you will probably never need the comp releases especially at 5000 elevation, I am running 10.3(10.5 pistons with .040 HG, 251 cams 103" 08 FLHX) in So Cal and have never experienced a problem....yet. I may go to a earlier closing cam , around 42 degrees and if I do I may consider the auto releases as my heads(SE MVA) are already machined for the auto's and I am running the SE Pro Super tuner.
