Change from 5 Speed To 6 Speed
I traded my 02 RKC for an 09 SG. I was trying to be careful breaking in the 09, but I hit the rev-limiter because the 02 didn't have a tach or a rev-limiter. I didn't realize how I RPMs I cruised on my 02 until I got the 09. Even with the six speed of the 09, I get about the same gas mileage as I did with my 02 at the higher cruise RPMs.
Beary
Beary
I agree Graham...It was just habit for me...after 45k miles on my 6 spd...i do the same on my wife Suzuki...No big deal...i would get use to it like anything else./...
I have the 103 kit on the 06RG and installed the Baker DD6. Well worth it and the motor handles it well. You can have a choice of first gear ratios. One that is pretty much like the stock tranny and the other is a little taller. I opted for the taller gearing because the 103 will wrap up in first gear pretty fast. Be sure you have the heavy duty pressure plate on your clutch when running a 6 speed. The stock plate has a pink rectangle on it so it makes it easy to tell if the builder did the upgrade.
I run an S&S 107 and have the stock evo 5-speed. My wife and I have just got back from a 2,500 mile tour of Europe and punched along at up to 95mph (on German autobahns!). It really is OK to travel along at around 4k rpm in top gear - nothing stops it!
So let me understand this. Will the taller gears give me less RPMS at say cruising speeds or more. I know my 08 SG gives me about 2500 at 70mph. From reading their website it appears that the DD6 is their top of the line transmission. How does it compare cost wise to the SE version. I am assuming these are both bolt in in either case. I really apprecite all this info guys. Thanks again!
But the Baker DD6 is a direct drive gearbox, so will not change your top gear at all. I live in the UK and cannot comment on US prices, except they are cheaper!
As far as the performance between the SE and Baker, I have been told by, who I would consider a competant indy that the SE is not a durable as the Baker. The Baker uses back cut gears for better upshifting, while down shifting, ya need to be a bit more forceful than with the stock tranny. In other words, were the stock tranny, you can just kind of tap it down a gear, the Baker needs a little more force or else you will get gear grind. I got used to it pretty quick and it doesn't bother me anymore. The indy claims that he has down quite a few jobs of cleaning the broken SE gears out of the gear box.
I kicked around the idea of getting a 6 speed on my SG but it gets over 40 mpg's as it is even with a passenger. I also like the fact that at highway speeds, I'm in my power band and don't have to down shift to pass like I've heard some of my friends that ride sixers (6-speeds) having to do.
Flip.
Flip.
