I have my first 1000 miles on my 2010 Limited and find 6th gear at 60-65 MPH provides no passing power at all. At what speed do you shift into 6th gear?
I usually don't go into 6th until at least 65. I usually downshift to 5th to pass. I have actually found that I get better gas mileage cruising in 5th gear most of the time anyway. So I reserve 6th for cruise control at around 70-75 mph. I usually don't go much faster than that anyway.
I don't look at the speedometer.....if I'm in 5th on the highway and I'm getting above 3,000 rpm....then I'll use 6th.......if I drop rpm below 2,500 then I'll go back to 5th.....I like the 3k range on my limited....I always drop to 5th to pass....even riding 1 up.....I like to keep the engine responsive if I'm passing.....
