cruise control install
I have installed the cruise control on my HD Electraglide Classic 07 and followed the instructiion that came with it and also read the manual along with the install that I ordered from HD. I have done the Cable lash initialization by the book and it worked just like it says in the book. when I test road the byke and used the set the orange turned to green but the cruise does not set the speed. I am wondering if I missed something or is there another step that I need to do? Just need a little guiding light.
You might also be able to diagnose the problem if it's a Diagnostic Trouble Code:
https://www.hdforums.com/forum/engin...and-codes.html
pulled the gas tank and used the ties on the cable put everthing back together and then did the Cable lash test and the darnest thing it worked just like the book said and the green light went out as soon as the engine started to rev.
took the byke for a test dirve and it works like a charm. Thanks for the tips guys. Yehaaa! I is working. : )
I just added cruise to my FLHTC '07 this past weekend. Not to rub it in, but I love it. Did you get the throttle cable to snap to the carb/induction thing. Also what about the E clamp that holds the cable in place in the same area under the air filter?
One other thing I think I remember reading, that cruise only work on 4-5 gear? I haven't tried on 6th gear. But if you are in 3rd, I'm guessing it won't work.
