bike dies while riding
2003 Electra Glide dies while riding.All power shuts off,couple minutes later bike comes back on. Local dealer says can't tell whats wrong until bike shuts down for good. the bike may run one day or one month before shutting down again.Last night lost power just sitting at a red light that was a first.
Another thing recently experienced on a friend's Ultra was loose cells in the battery. It was tough to nail that one down. The battery checked ok under a load test, but if you shook it around, it would drop out. At an idle when the vibration was most was when the events were most frequent. Glad we got it resolved with battery replacement. Just another thought...
Link to a thread of a member with simular symptyms on a 00' Ultra, simular suggestions made. Read it over see what he did, or even PM him to see if he ever figured it out.
Nate
https://www.hdforums.com/forum/touri...0-puzzled.html
Nate
Had similar problem with the '03 FLHTI. Fired the bike up and was in garage grabbing gloves and helmet, when it died. Went out and it fired right up. Did this several times while sitiing on it. Thought, well using up the battery with the lights and spots on, so turned off spots and the bike didn't quit again. Mind you its 105-110 these parts now. Took it to dealer. They replaced circuit breaker and rerouted the amplifier wiring. Everything fine for week and down at the shop and went to leave, nothing doing. No lights, starter, volt gauge dead, but horn loud and clear. Dealer rolls it it shop and 15 minutes later the bike is returned running fine. Explained the circuit breaker is right behind rear cylinder and the problem is with the heat. Told needs to be relocated from rear cylinder location. Will take care of that myself next days off.
