I have 2001 FLTRI that I cant start using the start button. I can start it at the starter with no problem. All electrical works - lights, speedo, etc. Already have new battery, checked all grounds, and had the starter checked. The switch is getting power to it and has spring in it. The run switch works but the start button doesnt? When I depress the start button there is nothing....no click, no engaging of starter. My guess is bad switch but just wanted to see if anybody could think of anything else to check.
Take a test light to ground and unplug the starter wire at the solenoid. Put your test light on that wire and hit the start button, you should get a light. If so, your button is good, if not the button is bad.
If it is good you probably need to pull the solenoid and clean the contacts.
Installing a starter button on the solenoid doesn't affect security in any way. You still need the ignition turned on and any security system disabled to start the vehicle.
