Check engine light
Check engine light
I am looking for some suggestions.
I was riding down the road the other day and my engine light and battery light came on. The voltage meter showed around 10 volts also. I stopped and turned the ignition off, restarted the bike and everything is fine. No warning lights on and volt meter is up to 14 again. I rode around the rest of the day and all is fine. Next day on my way home from work here she goes again with the warning lights.
I got home and checked the trouble codes. The only code it shows is P0562 which is low battery voltage. I plan on cleaning the battery connections and ground connections today to see if that helps. Any other suggestions? Is the charging system going bad?
Thanks!
Don
Thanks!
Don
Thanks for the leads guys!
I am going to check/clean the battery cables and connections. Hopefully that takes care of it.
The battery is about 2 years old now.
Does anyone know the procedure to check out the voltage regulator and/or stator myself or is this a shop check thing?
Thanks again
Don
Thanks again
Don
If you are unsure of how to do it, grab a Electrical Diagnostic Manual and it walks you through the steps with pics. The troubleshooting flow charts are gold too. They basically walk you step through step to evaluate the problem and identify the fix needed.
X2, really pissed me off too.
Before I figured it out I was in rush hour traffic and bike stalled
when I was trying to make a left handed turn no less, almost got it from behind and from in front from the morons trying to run the amber then red light .
Anyways, check your connections and grounds as well.
Hopefully that is what it is, cause it may or may not leave a trouble code for you.
Rob
Rob
OK, here is a new update. I cleaned the battery and ground connections and everything seemed to be working fine. Yesterday, a month after the original problem, it does it again. Engine and battery light on, voltmeter at about 10. I tried to make it home but didn't quite make it before battery went completely dead. I could see the voltmeter dropping as I rode.
I just picked up a new battery because obviously now my battery is dead. The question is if that is all that is wrong? If the battery is bad will the warning lights come on like that? Seems to me that it is not charging properly. I would think that if it was charging then the voltage would not continue to drop like it did. But maybe if the battery is a goner it won't accept the charge.
What do you think??
Don
What do you think??
Don
