Auxiliary Fuse Block 09 EGC
I have an 09 EGC and I currently have five accessories (2 heated liners, amplifier, battery tender and air horn) attached to the battery. It’s getting a little too crowded in there so I’m looking into the use of an auxiliary fuse block.
Is anyone currently using one and if so what would you recommend? Since there isn’t a lot of room under the seat is there a better place to put it? Any information will be helpful.
Thanks
Thanks
Along the same line as Dawg. I plan on added this with a relay this winter. I'm installing it under the fairing so I only have one conection to the battery.
http://www.centechwire.com/catalog/panels/ap1.shtml
http://www.centechwire.com/catalog/panels/ap130.shtml
I use the PC8 from easternbeaver, but Curt at www.fuzeblocks.com also makes a nice one.
I have 2 sets of heated gear, driving lights, battery tender, intercom, & hyperlites connected to mine. I still run my air horn straight to the battery.
P.S.- Jim @ easternbeaver also makes very nice wiring harnesses for all your goodies like air horns & driving lights.
where the heck are you guys mounting the block? I have no room under the seat and not wanting to run all the way up to the faring (access issue as well as PITA issue!)
There is a little shelf near the front of the battery but that is all I can see for a flat surface. Pics??
