Dyno Results Help
Dyno Results Help
I had my bike dynoed yesterday and need help if the results look correct for SE 255 cams? The dealer had a special on dyno tuning so I had it dynoed tuned. I have a TTS Mastertuner and tuned the bike myself. Here are the results before and after the tune. I have SE 255 cams, V&H's true duals. monster ovals and SE heavy breather. Please tell me if my dyno sheet looks correct or should I have better results? Thanks for any comments or info.
the curve looks ok. My bike is bearly putting out more with all my engine work but then again im 7000 ft above sea level
How does the bike run/ride? I have the 255's with Rinehart TD's and the bike runs real good! After a couple hundred miles on the PC-V & auto tune (base mapped by Fuel Moto) I never felt the need for a dyno tune. Starting a 103 build next week with diffrent cams and hoping the new base map will work as well as this one has!
I got smoked by that exact set-up yesterday! SE255 cams made a BIG difference in his bike! I was stock doing about 90mph side by side thinking I was keeping up, he dropped a gear and drove off! So, you might want to see how it runs out.....Thinking about this set-up myself now!
Dyno
That's what I thought also....only 66 minutes. It seems to run fine...wasn't sure what to expect as far as numbers go. It has plenty of low end and runs smooth. Was thinking about doing a 103...but the dealer said there wouldn't be much of a improvement unless I had headwork done for an additional $1,000. I think the cams will do for now...
www.bigboyzheadporting.com
