The Deluxe hinge install was the first thing I did after getting my bike home. Looks awesome. The c.v.o. bikes should come with them from factory installed.
you would think so , $33000 for a Ultra trike and they still put those tin can hinges on , so they get another $50 and we have to put them on
Piece of cake project, I did mine alone just take your time and be be sure you use the right size drill bit and that is sharp or brand new new. Drill from the inside of Tour Pack out.
Do not over tighten the new hardware and be sure to have some loctite on hand.
Put on the new hinges this fall as well as the spring loaded retactor to replace the cable...tour pack not only looks 100% better, but is more solid and functional!!
Did the same thing to mine. I thought grinding off rivets by weather stripping with dremel was easier than drilling.
