Deluxe Tour-pak Hinges
Old Dec 17, 2010 | 07:35 PM
Teardrop's Avatar
Teardrop
Default Deluxe Tour-pak Hinges
I just got done installing the Deluxe Tour-Pak hinges and what a difference in looks. I had a buddy come over and lend an extra set of hands which sure made the installo much easier. If you want to upgrade your tour-Pak these are a must.
Old Dec 17, 2010 | 07:38 PM
2WheelGlider's Avatar
2WheelGlider
Any problems with the install? I have looked at them but drilling out the rivets seems like a scary proposition to me, just curious.
Old Dec 17, 2010 | 07:42 PM
mtclassic's Avatar
mtclassic
I installed them and it is easy. You are only drilling the head of the rivit off so the rivet can pop out.
Old Dec 17, 2010 | 07:44 PM
Teardrop's Avatar
Teardrop
The olny area that was hard was the rivets under the weather stripping. Other than that is was not that hard. It sure made the job much easier having and extra set of hands.
Old Dec 17, 2010 | 07:45 PM
FXSTS-88's Avatar
FXSTS-88
Installed them last year myself. An extra set of hands are helpful, otherwise it's a straight forward project.
They look so much better than the 'stockers'!!
Old Dec 17, 2010 | 07:46 PM
twodollarbill's Avatar
twodollarbill
Easy install....2nd pair of hand helps too.
Old Dec 17, 2010 | 07:56 PM
sifularson's Avatar
sifularson
I've done two sets of these. Here are my suggestions to make the job easier.
1. Follow the directions and remove the stock hinge pins and lid before you start removing rivets.
2. Drilling the rivets works however I found that grinding the heads off with a Dremel is much easier then drilling around the lid seal. You're working on the opposite side away from the seal.
3. Use blue tape to cover the paint in any area you are working. One slip with the drill or dremel and you'll wish you did.
4. You will need to drill the holes out for the new screws since the screws are slightly bigger than the rivets.
5. You will only need extra hands when it comes time to bolt the lid back on. I managed without help.
I think they are one of the best $50 upgrades you can make.
How do they look????
Old Dec 17, 2010 | 08:06 PM
Teardrop's Avatar
Teardrop
You are much braver than i am. I read the directions, looked over the tour-pak and decided i better call reinforcements before I screw something up.
Old Dec 17, 2010 | 08:25 PM
2010 ultra man's Avatar
2010 ultra man
Default Deluxe Hinges
The Deluxe hinge install was the first thing I did after getting my bike home. Looks awesome. The c.v.o. bikes should come with them from factory installed.
Old Dec 17, 2010 | 08:44 PM
bbstacker70's Avatar
bbstacker70
Installed mine this summer. The stock ones drove me nuts, what cheap crap. Looked like something from s 80's goldwing ! Just another item that should be stock on the bike that Harley can sell for $50. I agree that drilling the rivets is nerve racking.
