SE MVA Heads Valve-train
Old 01-01-2011, 09:41 AM
creep1's Avatar
creep1
creep1 is offline
Default SE MVA Heads Valve-train
What valve-train set up does the SE MVA Heads have ? Type of valves, spring, seals, guides ect ? Motors comin apart so nows my chance to upgrade this area. Maybe fueling spring kit? whos valves are best ? finally who should I send my heads out to set it up? Tman ? any suggestions
Old 01-01-2011, 10:21 AM
Eric in chicago's Avatar
Eric in chicago
Eric in chicago is offline
Give Larry a call. He is the Head Guy that we decided to use on our 120R crate upgrade. We (builder Jim Kennedy) and I decided to buy a couple of 120R's and see what else we could get out of them. Doing Tman 662 cams, S&S roller rockers, HPI 62mm TB for FBW. Larry got the heads to flow 330Cfm from 295Cfm stock. The man knows his stuff. Not a fancy website but he is one of the most respected head guys in the business. There are a lot of excellent folks out there, just do a search and see the # of hits that come up. Depending on what your wanting done, there is a porter for every budget.
Some pics/discussion around our headwork is here http://harleytechtalk.org/htt/index.php?topic=33658.0
Larry's website is http://larrysmotorcyclemachine.com/1.html
Old 01-01-2011, 10:27 AM
creep1's Avatar
creep1
creep1 is offline
So the MVA heads that come in the 113 kit and the heads on the 120R are the same?
Old 01-01-2011, 10:38 AM
Energy-Dude's Avatar
Energy-Dude
Energy-Dude is offline
Except for the 120R badging...
Old 01-01-2011, 10:48 AM
creep1's Avatar
creep1
creep1 is offline
im definetly gonna checkout larry site , would love to get more flow thanks. So back to the original questions. is there room to improve the valve-train ?
Old 01-01-2011, 02:25 PM
creep1's Avatar
creep1
creep1 is offline
larrys site is good enough. basic to the point. lets you know everything you need to know if your having that kind of work done. Thanks for the refferal. gonna call him monday
Old 01-01-2011, 06:27 PM
creep1's Avatar
creep1
creep1 is offline
Valve-train set up in the mva heads, anyone???
Old 01-01-2011, 06:41 PM
Eric in chicago
Try posting up over on this site, more tech discussion and a lot of exp/smarts over there.
http://www.*****************/forums/twin-cam-engine-mods/
Old 01-01-2011, 06:45 PM
creep1's Avatar
creep1
creep1 is offline
im on that board,rarely go on. I'll give it a shot
Old 01-04-2011, 08:19 PM
strokerjlk's Avatar
strokerjlk
strokerjlk is offline
Here are the heads in question.
120R MVA CNC heads worked by WFO Larry. these are YOURS Eric.
I got put on mandatory 12 hr shifts ,so my shop time just got cut some.
but not to worry it will be up and going in no time.
thanks again for your confidence
BEFORE Intake
After Intake
Before Exhaust
After Exhaust
Before chambers
after chambers
Quick Reply: SE MVA Heads Valve-train
