Best price on a 120 r
120R has lefty bearing and a forged SE crankshaft with a 4-5/8 stroke. The stock HD crankshaft is cast and a piece of junk. Not that the SE crank is great but the stock one is junk.
I have the primo pro clutch with the varible pressure plate. Do you think that will hold it or do i still need a heavier spring?
I just checked and the clutch has a black spring so i guess that will have to be upgraded too.
i have a d&d fatcat with a wraped performance baffle but i was thinking of selling it and going with a borzilla. Its 1 3/4 versis 1 7/8 primary pipe size.
Gold spring
Ordered the primo gold spring,andrews 31 tooth sprocket to remove some of the gear,and a D&D bosszilla today. Im going to take 1 tooth out of the gearing. I think first gear will be useless with the 120 and the 30 tooth sprocket. It already rev's very quick with the 106 I have now.
I have the complete rivera pro clutch with the varible pressure plate.
Rivera clutch
I was ready to buy the whole set up but i am finding that the stock clutch with the Aim vpc and gold spring is holding much more than this whole 1000.00 Rivera set up. Could it be that the Rivera does not like the 30+ ounces of oil bath? Way too much money to have slipping problems, they also have a sealed ball bearing in the outer basket for running their clutch dry i would rip those seals out and have the primary oil lube it which they told me to do today when i talked to Rivera and they also told me to run the primary oil low with their clutch,would sure like to get a clutch assembly that worked with a high tq engine when i spend a grand. Several builders are claiming the stock clutch with the AIM vpc and gold spring are holding close to 200 hp so why deal with the Rivera slipping in the oil for all that coin???
120r
Well I'm pulling the trigger on my 08 Fat Bob. So I'm going to call Capitol H-D in the morning and if they can do my bike for $4650.00. They will have it this weekend. I live in Ohio so its close.i hope they can do it. I know there will be some extra cost but involved but hell 120 CID wow.They can have my 96 its only got 10,000 miles on it . wish me luck.......
