the 120R is Home!
I have the Rivera Primo with gold springs. There is a dip in the torque curve. Hense the presumed slippage. Maybe it -should- hold, maybe different primary fluid.
The Tech did a good job, I went crate motor [as it came] SuperTrapp Supermeg 2:1, SE Heavy Breather [from before], and TTS. Tech was impressed with TTS features not available with the new HD Tuner. He mentioned atmospheric pressure tables as one off the top of my head.
Apparently there are some shims coming for the clutch that will need to go in as well. The were after a settle in period [break in period].
Took it easy last night, and it wasn't crazy until I cranked on 'er past 4000 RPM. Never redlined it, [I am supposed to be breaking it in] but it is a power on top motor. I'll end up changing cams either later this year or winter.
Gotta hook up the scanner. and get a new memory card for the camera.
Harry
Harry
120R - Slipping
Here is the Dyno Sheet.
I hope it is clear enough.
With the scan I cut off the numbers, So I entered them in. I am a little disappointed in the numbers compared to Harley's Numbers of 135/135. How did they get that with a SE Clutch?
Why is everyone having clutch issues?
I've got an email into Rivera as well.
Harry
Harry
Just got off the phone with Rivera Primo.
He had a look at the dyno sheet. Said to go over the clutch, as it should easily handle the 120R. Especially with the GOLD spring.
Also look at fluid level, too much isn't a good thing either.
He mentioned ATF, but where are we at with the SE Compensator?
So much for just going for a ride...
Rivera clutch
Harry
Harry
I sadly don't know what oil I'm using. I've got an email to the tech that installed it. I'm going to check the level and remove some if necessary. I'll chech the spring distance then I guess.
I wasn't there during the dyno so I'm looking at the sheet. My numbers are a little low, and clutches have been a big issue all around. (Judging by forum posts that is).
