sirius antenna install
Old 05-18-2011, 10:16 PM
ltmdl90's Avatar
ltmdl90
ltmdl90 is offline
Default sirius antenna install
I just installed my sirius antenna in my faring on my ultra limited. It was painless and works great. So if you are planning to do this install it is very easy. And i made my own bracket for it in the faring. No need to buy one. I was very skeptical about installing it inside the fairing. No need to worry.
Old 05-19-2011, 12:21 AM
Dbaudio's Avatar
Dbaudio
Dbaudio is offline
Good to know...I just installed mine in the fairing last night& it works great on the driveway, but I was a little worried about out on the road & on cloudy days, etc.
Old 05-19-2011, 02:07 AM
drspencer's Avatar
drspencer
drspencer is offline
Can the stock Street Glide antenna be used for satellite radio?
Thanks
Old 05-19-2011, 04:51 AM
glide2005's Avatar
glide2005
glide2005 is offline
Thanks
No, satellite has its own little hockey puck antenna. If you have your sat. radio going thru the axu. port, you don't even need an antenna for your regular radio.
I had mine stuck to the top of radio under the fair and it would loose reciption real easy, so I relocated it on the shelf above the right speaker with double stick tape. All is well now.
Old 05-19-2011, 04:59 AM
ltmdl90's Avatar
ltmdl90
ltmdl90 is offline
I have 3 bars of signal. i used a piece of metal for a mount. I am a firm believer of a good ground for a antenna for proper receive.
Old 05-19-2011, 11:15 AM
drspencer's Avatar
drspencer
Is this shelf inside or outside the fairing?
Thanks
Old 05-19-2011, 12:22 PM
Pa-Rider's Avatar
Pa-Rider
Pa-Rider is offline
I just ordered my XM receiver and I can't wait to get it on there..
I'm so used to having it in my work truck, and I've discovered that I just have to have it with me on those long rides on the bike as well.
Old 05-19-2011, 12:26 PM
TickTock's Avatar
TickTock
TickTock is offline
Seriously - Pics would be very helpful to see how you made the bracket and where you attached it.
Old 05-19-2011, 03:16 PM
ltmdl90's Avatar
ltmdl90
ltmdl90 is offline
Sorry no pics of bracket. Just found a old piece of metal bent it and drilled a hole and mounted it above the left speaker.
Old 05-19-2011, 03:20 PM
ltmdl90's Avatar
ltmdl90
ltmdl90 is offline
Thanks
Inside the fairing.
Quick Reply: sirius antenna install
