Jackpot Mufflers Quiet Baffle Silence Insert
Hello all,
Installed a set of Jackpot Dyno Tuned pipes w/ end caps. Love the deep tone. I got the quiet baffle as well, for me, it's almost too quiet with the silent insert in, but too loud w/o it. Also a lot more decel pops w/o the insert in place.
Has anyone modify or drill out the insert to make it "in-between"? The search results in most folks leave out the insert, some even drill out the quiet baffle, but not the insert. What's the best way to modify the insert?
I might be one of the very few who feel even with the quiet baffle, is just a shade too loud.....
Hello all,
I too have wondered if you could open the insert a bit, like maybe re-shaping it from an oval to a round shape. That would help, but I still think it would be too great of a performance hit. The Quiet Baffle affects performance over the standard baffle, but not much, and mostly above 4500 rpm where I don't go often. I'm not willing to take a performance hit that I can feel, so I'll probably just endure the irritation I experience only a minority of the time, which is mostly only on the highway on grades or against a stiff headwind as the pipe give a hammering effect which grates on my nerves. This is not the fault of the mufflers, but mostly a side-effect of the cam change.
I was thinking on the outlet end on next to the hole in the center. If that's not enough, then the inlet side 180 degree offset.
Just talked to Keith @ FuelMoto, he said they haven't try to modify the insert. He suggested maybe break the weld where the inlet/outlet joint together, so the exhaust just have to pass through a flattened inlet, then straight out.
I also ordered another insert ($15-$20), so if I mess up, I've got another one to experiment with
I'm in same boat. Just went from Dyne tuned to their 4". I have 255 cams in mine and even with the baffle it's too loud for me. Please post if you find success with the insert.
I had the 3 1/2" Jackpots on my SG and have the 4" on the RK now. To me the sound is deeper on the 4" mufflers, while the 3 1/2" seem to be a higher pitch tone. But then with my hearing I may be all wet. At cruising speed (55-75)there is no droning or "hammering effect" but, I am not running any cam or plan to.
