Help Grinding noise on start
Maybe this will help - I had a starter go on my 08, fortunately the dealer covered all costs. https://www.hdforums.com/forum/touri...rter-goes.html
Assume that you do not have kick back - check your starter attachment bolts. had that noise problem too, which I ignored. Then later, got the no start problem. Went back and tighted the starter nuts and both the grind noise and the no start problem went away. I do expect the problem to return. when you tighten the starter bolts you will see what I mean. While in there, there's a bracket that goes from one of the starter bolts to the engine case, that will usally be loose too. Now, if you have kick back...whats that....well if the bat voltage drops too soon, the starter looses tourqe and plays fist fight with the engine. the starter usally looses and you hear the grind noise. check your battery terminals and if you have things like battery teather, oil cooler fans, extra lighting, cig lights, etc attached to the battery terminals, you probally have a crappy battery start connection. If this is the case, take all those connections off and move them to either your accesory lead or to the fuse box using fuse extenders.
