Some thoughts on the front fork air baffle
Jlandry (04-21-2019)
Received 71,054 Likes
I installed a baffle about a week ago. Probably rode about 100 miles or so since in 90+ temps and haven't noticed any pinging. I also didn't really notice a significant reduction in wind either. Probably because I am running a 6.5" Klock Werks shield. Wish I had bought the 8.5" instead. Lessons learned the windy way I guess....
at least you know your cylinder head engine temp sensor is working correctly....as the heads gets hot...the mixture goes leaner. I put a 3/16th lock washer on m sensor to pull the sensor tip away from the heads. There's an air gap now between the sensor tip and the heads. If you have a stage 1, you can pull your egg intake cover so that the cover cup effect does not suck in engine heated air.
