Oil leaking on my left fork seal?
I having oil leaking and I can see it on the left upper slider cover? It's making one heck of a mess.
I did grease the sterring head until it came out of the upper and lower as the service manual said to at the 1000 mile service.
I did think that was where the oil was coming from so I cleaned all the grease up a few weeks ago, but I am still seeing it and its blowing up everywhere when I ride.
I called the dealer today and said I think I have a fork seal leaking and was told it was probably the sterring grease, I was ask if it was on the left side which it is, he said if it
was a fork seal leaking it would be running down the slider and since I am seeing it on top of the slider cover he thinks thats the prob.
Anyone had this problem?
Thanks!
Thanks!
RE: Oil leaking on my left fork seal?
I too have noticed this. I too thought fork seal. You do not see it dripping, or see it in a fluid or grease state. You simple see small streems where dust sticks to it. I have also gotten it down on my left boot and primary cover. It was indeed steering bearing grease. I could not bleieve it. I thought for sure it was a blown fork seal.
Same thing happened to my old RK. I filled steering head with greese through the zerk fitting. In warm weather, It would drip an oily residue onto the slider, and look like a fork leak. I don't know how to greese the steering head any other way without taking it apart. I would wipe the bottom of the steering head with a rag to clean up any residue. Eventually it stopped.
