Probably running lean - going to install PC - idle adjust first? 2000 Road King
A newer Power Commander? Isn't the PCIII USB the most current model for most bikes? I know there's a PCV, but it's for very current systems, no?
The AC stock comment refers to going back to a stock element to reduce the air flow, thereby increasing the fuel ratio. Even if you went to EBAY and spent $20 you'll find someone getting rid of a stock element, I'm sure. ( Even a dealer might have a used one lying around.)
I think I might be looking at a fuel pump issue as well. Will look into that and the ubiquitous fuel-hose wear.
Zero map should change nothing as you suggest.
My bike idle "swells" on cold startup up too, on hot it just starts at 1050 and stays there.
Don't know much about Power-Vision..
Man, I've read so much about FI systems, fuel management, tuners, replacement ECMs...got myself a bit confused. Gotta back up.
Did a lot of reading at the RB Racing site. Them's some opinionated folk! Seem to know their stuff, though.
In summer, 1500 for 2 or 3 seconds, then 1200 for a minute or two.
In winter, 1800 for 5 or 6 seconds, then 1500 for a minute or 2, then 1200 etc.
oldlefty
05-18-2015 11:17 PM
