is anyone using Nitrogen in their tires?
Old 08-05-2011, 11:49 AM
pargenz's Avatar
pargenz
pargenz is offline
About the only advantage I can see is that a tire inflated with nitrogen should be purged of moisture, thereby maintaining pressure more consistently, while inhibiting any corrosion.
That being said, I'm happy running just the 78%.
Old 08-05-2011, 11:59 AM
RGfan's Avatar
RGfan
RGfan is offline
I use it in my autos, and used it in my previous bike. I plan to put it in my tires when it's time to replace them.
Biggest advantage, IMHO, is that it keeps the tire pressure consistant no matter the temp, and eliminates moisture. Have heard that tires will run cooler with nitrogen, but have no proof of that. You know....it's one of those things that "they" say. And
you know how "they" are about that.......
Old 08-05-2011, 01:02 PM
aktid35's Avatar
aktid35
aktid35 is offline
The Ideal Gas Law
PV=nRT
P = Pressure
V= Volume
n = moles
T = Temperature
R = 62.364 L Torr mol^-1 K^-1
This equation states that temperature and pressure and related, the pressure will always change relative to the pressure and vice versa. Nitrogen must also abide by these rules. The only gain you would see from it would be that it would be dry. Assuming these people are getting N2 from reputable places with lots of filters in thier pumping station ie. Air Gas. Versus compressed air which we all know has water in it most times due to humidity. N2 will leak out of your tires just the same as air, due to N2 molocule being smaller than O2. This is just my $.02 on the matter, not jumping on anyones case. Personally I'd fill my tires with Helium lighter is better
Last edited by aktid35; 08-05-2011 at 01:03 PM. Reason: Dropped a sign, Always did that in school too
Old 08-05-2011, 01:04 PM
carpetride's Avatar
carpetride
carpetride is offline
I use pure xenon because it's heavy which gives me better traction.
Old 08-05-2011, 01:05 PM
dnitram's Avatar
dnitram
dnitram is offline
Like PF Fliers, my bike can run it's fastest and jump it's highest...
Old 08-05-2011, 01:44 PM
SteveO's Avatar
SteveO
SteveO is offline
Waste of money....it's a gimmick !!
Old 08-05-2011, 02:25 PM
streetglide44's Avatar
streetglide44
streetglide44 is offline
I run it in 4 trucks and 2 bikes. Maintains pressure level
Free at my indy Svc center
Old 08-05-2011, 03:15 PM
wheel752's Avatar
wheel752
wheel752 is offline
Put it into my two trailer tires, a few years ago...now about 78%.... like to be on the cutting edge of technology.
Old 08-08-2011, 09:43 AM
Misbehaven's Avatar
Misbehaven
Misbehaven is offline
Man I haven't had a pair of PF Fliers since the late 60's.
Old 08-08-2011, 11:04 AM
Very High Plain Drifter's Avatar
Very High Plain Drifter is offline
Only at night.
Quick Reply: is anyone using Nitrogen in their tires?
