Oil Pump Nightmare
Screen I was referring to was just a wire mesh screen. No there is none on the scavenge side but though they may be one one of the suction side for the intake for the pressure side.
Just how tight is the bore on the inner oil pump drive gear on the crank shaft. It has the flat for the drive but since you have to jig it with alignment pins to center it, I thought it was rather loose and the inner diameter floated on the crank
You read this ever now and then. What amazes me is not one ever has a picture to show of one that is torn up. I can believe something getting in the oil tank or system and starving the pump but even then it would have to be totally blocked to destroy it. Half starved the cylinders and lifters would let you know you had a problem. I would get a second opinion of the price. Toyota dealer told my son his 89 Toyota 22 R needed a new engine for a $5500 installed price tag. We put new piston pin bushing in it (the problem), some gaskets, thru in rings and bearing shells for about $300. Not sure if the pump pressure side has a screen but I know the return side does not. However the gears are hard like bearings and run in a precision aluminum housing. All automobiles have similar systems with little more then a screen. The item 108 baffle asby probably has a coarse screen in it in your oil bag mounted under transmission.
Thanks for the picture, guess we are stealing St's post but he wanted a discussion. Back in your original post of your sprocket I had ask was the press fit what broke this and never saw an answer. Did Harley ever own up to it. I had a similar experience with a pressed on damper and the seal was leaking. It was cracked just like this and the crack had taken out seal. Is this sprocket normally a press on the cam? Is that the return side of the oil pump rotor? What did the pressure side lobe look like? Your photo makes the oil rotor look like aluminum but the ones I have dealt with are case harden (surface harden) cast steel that are hard as a cutting tool. However ingesting large hunks of metal is asking a lot. My guess why Harley did not put a screen on the intake and they are two for the scavenge side (sump and cam case) is there is not a lot of room and the plastic shoes could stop it up.
https://www.hdforums.com/forum/touri...an-planed.html
Here is a pic from my blown pump this summer. I was able to get it back up and running for less than 275.00. I had to pick up a new pump and was able to find a used cam plate for 50.00
My pump failure was due to the end breaking off the C-clip and being sucked up the pump. This was caused by my own negligence having the washers mixed up on the cams. The cam with the C-clip was a little tight and when the engine got and cold the cam would expand and put even greater force on the clip till the ends finally failed and landed in the bottom of the cam chest till being sucked up the pump.
Just how tight is the fit on the inner rotors of the oil pump on the crank shaft drive? Would you describe it as loose? When you slide the oil pump on and align it before you put the temporary alignment pins in will it shake up and down .010-.015? I assume this alignment procedure is to allow for crank pin run out. However .003-.004 at chain sprocket would only be .002 or so at oil pump.
If your having this fixed you should be upgrading to screamin eagle hydraulic cam chain tensioner and high-flow oil PumP upgrade Kit part # 25284-11 (page 81 SE catalog)
You also need to check your crank run out. I removed my oil filter and blew compressed air through the oil galleys. Changed oil and filter
