6 gallon tank on 07 ultra
I'm not sure you can do this. From 2008 onwards the frame is different
Check this one out.. looks good to me and will be ordering one in Jan
http://justgastanks.com/p1747/Paul-Y...duct_info.html
I just posted this on the other thread.
When the 6 gallon tank can out on the 2008, there were many questions about if they can be mounted on earlier frames?
It can be done but with many part changes and welding on the frame. To change the mounting locations for the motor will require removing the motor to cut the old locations and weld the new one in place.
The motor mounting locations were changed along with the location for the coil and a new seat.
The Fuel Tank and seat points mounting points were moved. The seat was changed to make room for the new tank. The seat does not have the same mounting locations. They are not even close.
The 6 gallon tank has made the '08 frame a "One Year" frame.
