best tuner
best tuner
I have looked, but I can't find a thread asking this basic question. I'm getting ready to get a 2012 SG and wanted to put new true dual (possibly Rhineharts - worried about sounds overpowering stereo), stage one, and a tuner. The problems is I don't know which tuner. I used to own an 07 RK with True Dual Rhineharts, Big Sucker Stage one, PCIII. Loved the setup except the PCIII was not an autotuner. I'm not sure if that really matters.
I'm just wanting to ask which tuner you have and are you happy with it. I know most parts are personal preference, but I think this one it is important to get some reviews. So here it is, I'm asking for reviews on any tuner.
I've got the PC5 with autotune, some members say they don't like a piggy back setup. I agree but I already had the PC5, the autotune has been working great. Starting out again, I would go with the Power Vision because I know Power Commanders work and FM is 8 miles from me.
Received 70,434 Likes
Don't worry, your stereo will be underpowered if anything...
As far as tuners go, if you're not into dyno-ing check out Revolution Performance..
The Revolution Performance will auto adjust to new pipes, cams, etc.
That is the brillant feature of this system, unlike the others, and if I had it to do over again the one that I would go with from the start..
I've got a Power Commdander V and it works good, but you need to have it dyno-ed for maximum usage..
Many on here use the PC Autotuner as well and it works in conjunction with the PC-V, but my last tuner dude stated that it messed up his tunes and he recommended taking it off, so I did.
My new tuner dude likes them, but I don't think that I will get another auto-tuner..other than the Revolution Performance.
Hope this helps and it is a lot to think through, I know..
the power vision tuner is suppose to be a great tuner....I use a PCV and it works great for me, I just set it and forget it...some folks who are more,, lets say picky than me like the PCV with the autotune....but the power commander powervision is suppose to be the latest and greatest these days...
Less Is More
For me, less was more. I put on a set of slip on mufflers on my 09 Road King. The bike developed popping (running to lean) with a downshift decel. I purchsed and installed a V&H Fuelpak after I got in touch with V&H to make sure they could recommend a MAP setup to solve the popping issue. I don't plan on doing ANY more performance mods. The installation and setup was about as EZ as it could get. For a "basic" mod setup (air filter/exhaust) this is a great product. ANYTHING after that I would recommend a more advanced tuner!
depends on what is important to u tts is best but...u will have to pay for a dyno tune or take time to learn to tune it yourself.sert is a close second simsialer to tts.pcv plugg and play get it from fuelmoto it will be premapped for your setup,dyno tune may gain a little performance or better milage if u find a good dyno operator to tune it but fuelmoto maps are very close for a (canned map) ar u can add auto tune to pcv but again theres a learning curve for u. not up to speed on power vision.dealer download does very little basicaly a map for screaming eagle parts,still tends to be lean as it is epa compliant those that went from download to a tuner of any kind have seen big gains over the download. xied pluggs inline on o2 sensors make for richer tune when ecm is in closed loop mode, i had em and they were a slight improvment but didnt compair to a good tune.
