Battery Tender pigtail: what can I plug into it?
Old 12-06-2011, 12:34 PM
albngore's Avatar
albngore
albngore is offline
Default Battery Tender pigtail: what can I plug into it?
So I got to thinking that I already had the tender pigtail with the standard fusing connected to my battery and I wondered what could connect to it, such as heated clothing?
I already use my cigarette lighter for my GPS and that works fine. I have some bag wrap-around lights connected to my auxiliary switch on the dash and that works fine too. Anyone connect heated clothing directly to the battery tender pigtail?
Thanks.
2006 Ultra Classic
Old 12-06-2011, 01:01 PM
Jinks's Avatar
Jinks
Jinks is offline
Do it the other way. Connect heated clothing coax cable to your battery. Then get the adapter that adapts the battery tender to coax. The cable attached to your bike works for both heated clothing & battery tending. The coax adapter on the battery tender keeps you from plugging & unplugging the two prong plug from the battery tender. That is the battery tender's most vulnerable point. Constant plugging, unplugging causes the male prong to compress & it quits making contact. It's easy to fix, but if you don't have to fix it, why bother?
Old 12-06-2011, 01:06 PM
sedouglas's Avatar
sedouglas
sedouglas is offline
You have an Ultra, why not a refrigerator? You have the room
Old 12-06-2011, 01:33 PM
clarkchriston's Avatar
clarkchriston
clarkchriston is offline
Default Pigtail Options
Try this site. I purchased a cig, lighter adapter that connects one end to the pigtail. That way I can charge my phone, or use to plow up an air mattress or whatever. But then again my Road King didnt come with a cig lighter port....or a refridgerator. They also sell a bunch of options for heated gear plugs.
www.powerlet.com
Old 12-06-2011, 01:46 PM
FBFletch's Avatar
FBFletch
FBFletch is offline
As mentioned, one of the things you can get is single ciragette lighter plug with a battery tender plug. I have one of those and plug a three hole cigarette lighter unit into that and stick it into my saddlebag. The three hole unit I use for various things:
1) Phone Charger
2) Ipod Charger
3) Universal Cell Phone Battery Charger
4) DC/AC Inverter (which also has a USB port to charge various components)
With regards to heated clothing I think if you fish around, you can probably find a heated gear plug that has a battery tender plug on the other end. The nice thing about that would be to minimize the number of cables you have connected to your battery terminals. Right now, I have a battery tender cable and a heated gear cable connected to mine.
Old 12-06-2011, 02:58 PM
jberg's Avatar
jberg
jberg is offline
I have used mine for heated clothing and battery charging on a previous bike. I can't see a problem with anything you connect to it as long as it doesn't exceed the fuse and reason...
Old 12-06-2011, 05:38 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
No problem using it if you want. Just make sure that the gage of the wire of the pigtail will support the current load you plan to pull through it to keep your *** warm.
Old 12-06-2011, 05:43 PM
blockzilla's Avatar
blockzilla
blockzilla is offline
Baaaaahaaaaaahaaaaaa.......
Old 12-06-2011, 05:44 PM
TUCCI's Avatar
TUCCI
TUCCI is offline
Yeah there's probably room for a habachi.................
Old 12-06-2011, 09:31 PM
X Iron Butt's Avatar
X Iron Butt
X Iron Butt is offline
What He said.
The Habachi and the fridg is way too much load for that connector. You can unplug the fridg while you are using the Habachi though. Under 60 mph the fridg will stay cool for about an hour.
Quick Reply: Battery Tender pigtail: what can I plug into it?
