LED project on my 2010 FLHTK
Old 12-28-2011, 04:30 PM
ElectraEd's Avatar
ElectraEd
ElectraEd is offline
Default LED project on my 2010 FLHTK
I installed LED's on my 2010 Ultra Limited. Started a few weeks ago but was waiting for the surround for the Tour Pak LED's to get back from paint. I replaced the following with LED's: Front and rear running/turn/brake signals. brake light, Tour Pak, headlight and fog light. Still going to do the fender tip lights. I am ordering those from custom dynamics. Here are some photos.
Old 12-28-2011, 05:03 PM
groupw's Avatar
groupw
groupw is offline
........ your TP lightbar looks great colormatched !
.... do the LEDs give significantly better light at the other locations ?
Old 12-29-2011, 07:27 AM
ElectraEd's Avatar
ElectraEd
Yes! You can definitely tell the difference.
Old 12-29-2011, 08:07 AM
rk99's Avatar
rk99
rk99 is offline
Default Agreed!
I have replaced the headlight on my 07 RK and the difference in illumination is remarkable. Question, I see you set low and high beams - your driving lights didn't go off on high beams. If I go high beams, those lights go off on my bike.. what is the difference? I would like to keep all lights on whether in high or low beams...
Thanks.
Old 12-29-2011, 08:39 AM
NDBadlands4-2's Avatar
NDBadlands4-2
NDBadlands4-2 is offline
When I got my bike I put the LED's in the headlight and was amazed at how much better the light was. Since then I have wored my way around the bike and have put LED's in all the lights just like you. So much more light it is a huge difference.
Old 12-29-2011, 08:43 AM
tpcrawford's Avatar
tpcrawford
tpcrawford is offline
Very nice. I like the clean look of the tourpak lighting.
Old 12-29-2011, 09:14 AM
Talldog's Avatar
Talldog
Talldog is offline
Thanks.
See this thread
https://www.hdforums.com/forum/touri...always-on.html
Old 12-29-2011, 09:41 AM
ElectraEd's Avatar
ElectraEd
Thanks.
Not sure how to do it on an RK. On the Ultra you just cut the yellow wire coming from the switch and tap it into the Orange/Red wire the is in the headlight wire loom and not hooked to anything.
Old 12-29-2011, 09:56 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
In some states, simultaneous use of the high beam and the spotlights ( including aftermkt fog lights) is illegal. Doubt you will get caught unless you blind an oncoming LEO.
Old 12-29-2011, 11:40 AM
dansflhti's Avatar
dansflhti
dansflhti is offline
The tour pak lighting looks awesome,and a great color match.Did you use HD paint,or did your painter match it?What LED light are you getting for the front fender?I have the HD LED Run/Brake on the rear fender tip,but still looking for LEDs for the front fender.
Quick Reply: LED project on my 2010 FLHTK
