Rear Speakers Output from Stock HD Radio
Hello all,
Just ran speaker wires to the rear using the rear speaker output from radio, no output?
I thought it should have constant output even w/o dealer's flash, the flash only make the front/rear fader functional, am I missing something here?
Here is what I did:
From the 35 pins connector, pin #1-RR+, pin #2-LR+, pin #24-RR-, pin #25-LR-. I did have pin #13 and 14 (CAN + and -) connected to the CVO amp, which is powering the rear speakers with signal from front speakers output. Front fairing speakers are powered by an amp on top of radio, signal from low level RCA added by IronCrossAudio.
Any ideas? Thanks
Here is what I did:
Any ideas? Thanks
Hello all,
Here is what I did:
Any ideas? Thanks
Here is what I did:
Any ideas? Thanks
Honestly, I'm confused by the highlighted portion of your post where the rear speaker outputs from the HK are correctly identified, but you don't say to what they are connected--amp or tour pak speakers? And then you write that the rear speakers are powered by the amp "with signal from FRONT speakers output. (HUH???)
Just rewire so that the amp's rear speaker outputs are connected to the rear speakers and you'll be fine.
Carl
Carl
Unless the amp's rear speaker outputs are connected to the rear speakers, the rear speakers are not receiving an audio signal. By connecting the amp to the HK via the CAN + and -, the rear speakers' audio signal will need to come from the amp.
Carl
Carl
Thank you for your reply. Sorry to confuse you.
Here is the current setup on my rear tourpak speakers: I took the front speakers wiring from the HK radio, wire them into the CVO amp to power the rear speakers, trying to switch the wiring so the CVO amp is getting signal from radio rear speakers instead. I figure this way, all I got to do is have the dealer flash the HK so I can fade.
But after I switch, I have no sound from rear speakers, so I wire in a outboard speaker directly to the rear speaker output from the radio (bypassing the amp), no sound from both L and R.
Hope this make sense to you. Thanks for your help.
Guess I should have added this too. I have a J&M amp powering the front speakers. Can I just hook up rears to the output of the UOL harness or do I need a 4 channell amp? Also, in order to get the fader to show up on the HK, do I need to go to the stealer or will it automatically show up once speakers are installed to the rear output? Kinda like how XM showed up on the screen as an option once I had it installed. Hope I don't need another amp, they ain't cheap, not for just a little rear fill.
I had a dealer tell me that you won't get any output from your rear speaker jacks, unless you get the download. They said that the radio has to be told that there are rear speaker attached, for them to work at all.
Now, keep in mind, that's what a dealer told me.
Sometimes they're right, sometimes they're left...
