left leg roasting hot with rinehart classic true duals!
ill post this here as well as the exhaust section....
so i just swapped to come rinehart true dual classics...and my left leg bakes when im stopped. I have a 28" inseam so raising the seat isnt an option.
are there any thicker heat shields available?
is there enough room to wrap the pipe in header wrap then put the shield back on?
its 65* now...this definitely wont fly when its 90+
Thanks guys!
Thanks guys!
Yes there are other heat shields available. someone will chime in with more info on that. Yes you can usually wrap headers and still get the shields back on. Are you sure it's your left leg? With the under the bike crossover, I thought the left side wasn't a problem any more.
Buying headers with ceramic coating makes a big difference but the best option is to not create the heat in the first place. Get a good tune so the engine runs less hot to begin with.
Heat shields won't work with this problem. My buddy has Rinehart TD's & they stick out to far from the frame on the rearward bend on the left side. I have Freedom Perormance TD's & they hug the frame much better so I don't feel the heat. There is about a 2" difference between mine & his & it saves my skin!
